We have just created a customized version of DSEdit for the AzBox miniMe American Edition which allows you to fully edit and easily manage your receiver's channels from the convenience of your PC. It works best when both your receiver and computer are connected to your network as it allows channels to be edited on the fly without having to use a USB flash drive or rebooting your STB after each change.
It's very simple to get started as you simply have to specify your receiver's IP address under the Box IP field as indicated by the red arrow. No other fields have to be modified as this has already been done for you with our customized editor. To save your STB IP address as the new default, you would then click on Save Configuration and OK.
Transferring your current channel list is easy now that both your STB and computer are connected on the same network. Simply select Transfer from the toolbar and then the Read button to transfer channel and satellite information from your miniMe American Edition directly in the editor. You should see a message appear on your TV screen for a few seconds during the transfer process.
The organize lists tab allows you to easily view and modify channels from a specific satellite. You may also organize your channels into custom favorite lists simply by drag and dropping each channel to the desired list on the right hand side of the screen.
The edit settings tab allows you to easily view channels on a specific transponder. Current PID information for all channels can be viewed or modified on the fly. You may also add, edit or delete transponders over here as well.
The search tab allows you to easily search for specific channels by keyword.
The statistics tab allows you to view how many TV, radio, FTA or encrypted channels you have scanned on each satellite.
The transfer button on the toolbar allows you to easily transfer your channel list back to your network connected miniMe American Edition once all desired modifications have been made. Changes take effect immediately without having to reboot your STB. You should see a message appear on your TV screen for a few seconds during the transfer process and your channel list will be automatically reloaded by default in order to instantly view your changes.
You may download DSEdit for AzBox miniMe American Edition from the support section of azbox.ca or azbox.us
Best regards,
PwrSurge
AzBox Canada & US
Best regards,
PwrSurge
AzBox Canada & US
