Good question. Five mirrors which you used can locate the focal spot (useful, if the LNBF bar was missing or damaged). For positive verification of correctness of paraboloid, even 19 mirrors (which I used) would not be enough. This could be seen on the following photo. About 2-3 years ago I was experimenting with Seesat dish.I have done similar mirror experiments after having read your previous postings. Not to take anthing away from your insightful and meticulous trials, is it not enough to just place mirrors at the 12, 9, 6, and 3 o'clock positions and one in the center of the dish. If they all focus in a tight cluster onto the LNB surface then is it safe to assume that the rest of the dish surfaces are also in proper alignment?
I have an artical from 1985 that used a wooden fresnel lens for c band. It was made from 2 4X8 sheets of plywood and had the gain of a 6-8' dish.It would be fun to try to make one for Ku.
I've often stood in front of my BUD and wondered what it would be like to see the focal points of all the satellites across the front of the dish. Wouldn't it be easy to fine tune one if that stuff was visible?
On Nov. 19, 2013, primestar31 posted (#8) this article from Radio Electronics, (and this article is 29 years old... ) where its author ALSO included corrections of mistakes in this article. Most important, the efficiency of Fresnel dish would be just 15 dB, whereas same size paraboloid dish - 37 dB. Not worth bothering ...one of those fresnel dishes would be good for
a) somebody good at fabricating stuff that hasn't been able to salvage a c-band dish
or
b) somebody with uppity anti-dish neighbours. "that's not a satellite dish, it's a piece of modern art"
