Weird things can happen when you least expect. I get a call that the C-Band dish is no longer moving, ER2 on the VBox. So after a bit of checking with the DVOM I determined the VBox has failed. There is no power to the motor from the VBox. As luck would have it, my buddy has an extra VBox Installed it real quick and the dish is moving again. So to complete the job I start to program the sat positions into the replacement VBox. I get to the last sat and programed the position with the VBox remote as I did with all the others. I then go to surf thru a few sats with the microHD remote and the receiver starts to freak out. First it seems to ignore the remote commands and then it won't stop responding to them. IE hit the info button and it continually cycles thru both info screens and then off and repeat and repeat and repeat until you power off the MicroHD. Any remote command is continually repeated over and over by the receiver. Well it's almost useless that way. My buddy says let's try the other MicroHD from upstairs. Well would you believe it's doing the exact same thing, freaking out to the remote commands. I said there is IR interference happening here. I could shade the microHD and it would behave normally. Finally figured it out. When I hit the enter button on the VBox remote to assign the last sat position the enter button stuck down. The MicroHD wouldn't respond to that signal but mix it with the microHD remote signals and it goes crazy. Lesson learned, if the micro does this to you look for a interfering remote
