Mercury II transponder scan
bonscott87
925
Quick question here.
Say there are 3 channels on a transponder I want to add to my channel list. So I do a transponder scan and it turns up a dozen channels. Is there any way I can just select the 3 channels I want to add? It seems that the only choice is to add all the channels found or add none.
Reason is I'd much rather to a quick TP scan and choose to add those 3 channels then to add all 3 by hand.
Hopefully I'm just missing a function or easier way to do this.
Thanks!
The only way to add individual channels would to manually insert the TP and PID information of each channel.
The method of scanning the individual TP then editing out the unwanted channels is probably the easiest and fastest way to add channels.
From my memory: you add them all, then when watching the channel press the round button in the middle of the volume, channel up/down (Select?). From there, I think you press the blue button and you can select channels to delete...
Globecast receiver and Dish
