may 1st: RECORD HD PROGRAMS ON PC
armrh
23
Just found this HD PVR from Hauppage, will start shipping on may 1st. For those who want to record HD content on their PC I think this would be a solution, and i think it would match perfectly an H20 or H21 receiver.
HD PVR Product overview
HD PVR is the world’s first High-Definition video recorder for making real-time H.264 compressed recordings at resolutions up to 1080i. HD-PVR records component video (YCrCb) from cable TV and satellite set top boxes, with a built-in IR blaster to automatically change TV channels for scheduled recordings. Audio is recorded using AAC or Dolby Digital.
The recording format is AVCHD, which can be used to burn Blu-ray DVD disks. Two hours of HD recordings, recorded at 5 Mbits/sec, can be burnt onto a standard 4.7 GByte DVD-R or DVD-RW disk for playback on a Blu-ray DVD player.
The HD PVRs amazing recording quality allows personal archival of your favorite high definition TV programs from any component video HD set top box. The HD PVR also has standard definition composite and S-Video inputs so you can record your old home video tapes into an AVCHD format for creating Blu-ray DVD recordings.
Features
  • Built-in hardware H.264 high definition encoder, for high performance, high quality TV recordings
  • Component video input from most high definition cable TV and satellite TV receivers. Optical or stereo audio inputs.
  • Record high definition video at up to 1080i resolution, 720p or VGA/D1
  • Record at datarates from 1Mbs to 13.5Mbs, constant and Variable Bit Rate
  • Blu-ray format AVCHD recordings, so you can burn your TV recordings onto a standard DVD disk (up to 2 hours of video at 5MBits/sec) and playback on Blu-ray DVD players
  • Includes HD software video player, so you can playback recordings to your PC screen
  • Audio / Video component video loop through to allow HD recording and viewing at the same time
  • High Performance Noise Reduction Function
  • NTSC,PAL and SECAM Support
  • IR receiver for remote control
  • IR Blaster to change the TV channels in your set top box
Interesting product, have to belive that it will not have much copy protection problems yet being that it uses component inputs instead of HDMI.
I think I'm holding out for the Microsoft / DirecTV HD PC box that they are working on.
No idea when it will be available, but it sounds SEAMLESS - the best kind of setup.
If the Movie companies have there way protections is allready being implemented that will not show over 480p on a non HDCP port.
I got this from support.
The product is still in development, so likely when it first ships, you will be limited to using the software that it ships with for capture and scheduling purposes. It is likely that our developers intend to integrate it for MCE at a later time.
Regards,
Bill V.
BillV@Hauppauge.com
Technical Support
Hauppauge Computer Works
New York
For more online information please refer to:
Hauppauge Computer Works : Support
Please include previous correspondence when replying.
need help with hr21 reciever
Signal Trouble on certain channels
