Maximize Receiver
CACohenDVM
5
California
1) Is there any reasonable way to edit recorded programs? Not thinking ads, but being able to edit out maybe 2 hours if content if a concert and saving an hour of it.
2) External drives for greater storage. Use of a SATA drive, I understand works. Anything special to know?
3) Capturing external broadcast signals with a digital antenna. We live in a concrete & steel condo facing south in Marina Del Rey (LA), CA. Broadcast antennas live on the mountains to the northeast if us above Pasadena. How can I get signals via my own antenna in case DirecTV is out? I suspect a rooftop antenna might be best? Could I use existing older coax that is no longer in use? If not available, is there any unobtrusive antenna I could use on my deck or by a window? Would a Radio Shack signal booster help?
?thanks, Chuck
1 - nope
2 - esata will replace the internal drive, so it is like starting over. it boots off one drive, the other is disabled.
3 - rooftop would be best, if you have any old coax running into the building it will likely work fine, nothing special is needed for OTA.
Multiple HD Channels out
DIRECTV Announces Second Quarter 2013 Results
