Lost the tube on G10
randycorb61
42
hello guys
I seem to lost the tube on g10..what would the settings be again?
Thanks Randy :)
It was dropping very badly the whole weekend for me, at one point I noticed it went down to zero for a minute. At times it went back up to its usual 45% (Pansat 2500A, Winegard 76cm, "old" .6dB LNB).
On Saturday it was coming in on another channel on G10R as well. I did not note the settings at the time, (or noted what channel I was on at the time) but it was on another one I had scanned in previously. The programming just changed from the one feed to the Tube.
Thank You...Larry
I imagine the hurricane passing over their uplink had a little to do with the low signal levels this weekend.
Why is the Tube on such a weak transponder? Or is it just our location? I only saw momentary spikes of quality over the weekend, but stations like WPXW were strong and steady over the weekend.
numerous discussions on it....reason is cross pole
Dish 121 has a transponder that is stronger than the TP the tube is on...the bigger the dish, the better the signal :)
Pansat 2700: How Does It Work?help
eurobird 1
