Lost Sats 110/119 on 811 receiver only
pmart
25
Puerto Rico
Setup:
Two Dishes pointing at 110 &119 respectively.
One 2x4 LEGACY Switch
Two Std 311 receivers
One HD 811 receiver
Recently lost signal on 811 receiver and received message to do Check Switch.
After doing so, I have lost both sats (110 and 119) from HD 811 receiver only.
The other 3 Std 311 receivers still work OK receiving signal from both sats.
Any clues for what might be wrong ? I have reset receiver, done several Switch Checks but nothing seems to work.
Your usual response will be appreciated.
Pmart
Move one of your working receivers to the TV with the 811.
Take the 811 Satellite wire and connect it to the other working Receiver and connect to your TV.
If other receiver works and the 811 dosen't then your 811 is bad.
If the other receiver will not work then your wire or switch is bad.
Reconnect the satellite receivers in there orignal places, Now go to your switch take your 811 wire and switch it with one of the other receivers wires.
If the 811 works and your other receiver doesn't then your switch is bad.
If the 811 dosen't work then its a bad wire from the switch to the reciever.
Dish still have those HDtvs they were selling awhile back?
942 Display question
