I have my dish pointed at AMC 4 123w and HAD it working(Got a Quality signal)...but It lost the channel lock when it rained...so I went out and adjusted it with my sat finder for max signal. I think I may have bent my dish and or the lnb mount a bit trying to turn/adjust the dish. Also, how important is it for the mast to be level and plumb? My signal dissappeared after I tried to raise my dish on the pole(I thouht it might have been getting blocked by the neighbors garage when I was trying for G10)...had that one at one point too...but now nothing. I have tried moving the LNB up and down...and tried adding a washer under it to angle it up....tried washers on the rear dish mounts to change the angle of the dish mount. How can I check to see if my dish is bent or the lnb mount?
My setup is a Twinhan DTV 1025 pci card with about 50 feet of quality RG6 going directly to my Fortec star 80cm dish with the FORTEC STAR Single Universal LNBF. - (Model FSKU-V) mounted on my back porch. I'm in zip code 16701 (northwestern Pa)
I was just starting to have fun with this stuff and now I cant get a channel lock. I have already had luck/help browsing this great forum...this is my first post here...so thanks in advance!!
BMXerHS
BMXerHS
