Lost 110 and 119 SATS
fignewton
Kansas City
I have 3 recievers 2 of them are working fine, but one lost its connection to SATs 110 and 119 now it only finds 129. I have unplugged and checked switch but for some reason it will not lock in on either 110 or 119. Why would 2 of my receivers work fine but this one is acting wierd?
Try changing the coax lines so that the problem receiver is connected to a different output on the switch and see if problem stays with that receiver or appears on the exchanged receiver. If it stays, it is possibly a bad connection, coax line or receiver. If it goes to the other receiver, it is probably a bad switch/lnb (you didn't give complete info on your setup).
If it's a dual tuner receiver, check the seperator. The symptoms you state make me think that. Or line is bad.
Garys gave the best advice, unless the problem is specific to just tuner 1 or tuner 2. on the check switch screen, is the 129 still showing in the third box? Do the first two boxes show Conn, but no satellite or are they red X's?
Wow..What happened to VOD?
