Lost 103 satellite reception all other sats are in the 90's signal strength
Technically no lnb transmits everything as we have a 95 for international programming which requires an additional dish. The 72.5 is dead but that did need a second dish as well. But for all national programming the sl5 catches 99.101.103.110.119
:welcome to Satelliteguys Joe Clemmons!
I'm not sure what you are asking, but I'll give it a shot.
The 3 lnb sees 99, 101, and 103. The 5 lnb sees those, plus 110 and 119. Is that what you were asking?
the 101 and 99 signals don't use a 22khz tone with the 14 or 18 volts used to switch to different transponders at the lnb, where 103 does. although a bad lnb is most likely, if you are only using one receiver, a defective receiver could be causing the issue as well.
August Free Previews
Appointment for install is Thursday
