Hi. A few questions from another person that's looking to get started. (I can start a different thread if it's more proper.)
I'm looking to get into FTA Satellite. I'm not new to satellites in general, most of my resume is in the satellite industry. But my last home system was a Dish Network system that I quit using in 2008.
I mainly want RetroTV, but will probably just go with a motor and try to pull in everything that's visible from here.
I'm on the front range north of Denver, so I'm in prime footprint, with an EIRP between 48 and 50 for most spacecraft based on the Lyngsat maps. I was thinking of going with a Winegard DS2076, 76 cm dish. And then a motor for it. I also want a DVR, preferably one that I can stream over ethernet from other rooms in the house. Questions:
- Is the Winegard 2076 sufficient if I'm in a good footprint? Or should I go bigger? Will a bigger dish have better isolation between orbital slots? (I notice that the isolation spec for the 2076 is 2.4 degrees.)
- Is the Amiko Mini HD SE a DVR? Does it work as a server for streaming from PCs? Will it record ATSC from a HomeRunHD?
- Should I go with the Amiko A3 instead? Would I be trading features for stability?
- What LNB is a good choice? Are the X^2 LNBs any good?
Thanks.
