I am looking for a new FTA receiver since I want more features.
I currently have a Pansat 3500 and I like many of the features it has but I would like more.
So I would like a receiver that has the following:
-Fast and accurate blind/smart search. (The receiver should pick up the names if they exist) (Compared to the Pansat 3500)
-Automatically blind/smart searches the arc. (I leave the receiver alone for a few hours and when I come back it has scanned the arc.)
-Specify the start and stop frequency range to scan.
-Specify a range of Symbol Rates to scan.
-Specify the blind search step in MHz.
-SD Card or USB drive or USB connection.
-The receiver needs to be supported by Channel Master.
-Has some warranty support
I have a Twinhan102G so I do not need a STB with HD or 4:2:2. (I am picky about everything else except for that ) Not that there will be a receiver that does that other than the Quality series.
So I looked at the following receivers: Traxis 3500, Mercury II, VISIONSAT IV200, Coolsat5000, Coolsat6100 Private. (What else should I look at?)
1. The Traxis 3500 only has a serial port, not sure about other features.
2. I found out that the Mercury II only has a Serial Port connection and it is not supported by Channel Master.
3. I read that the VisionSat has a slow blind search and I am not sure about the other features.
4. I looked at the Coolsat5000, it seems to have all except it only has a serial port connection and it is no longer warrantied from the manufacturer.
(Does the Coolsat let you specify the frequency range, the symbol rate range, the step size, when you blind/smart search multiple satellites?)
5. The Coolsat6100 Private has warranty but it is not supported by Channel Master.
So is there a receiver that comes close or has all the above features?
Thanks.
Thanks.
