C chadg2 SatelliteGuys Pro Original poster Apr 2, 2006 623 42 Maiden Rock, WI Sep 25, 2011 #1 is there such a thing as a push button a/b switch that can pass 13/18v and would work for FTA? This would bypass the diseqc switch all together, I would just have to manually push which lnbf I want to run. No big deal!
Pixl Senior Member Pub Member / Supporter Feb 27, 2010 1,902 67 Traverse City, Michigan Sep 25, 2011 #2 This one from Channel Master says it can be used on a satelite. I've used CM switches in the past, they were well built. Channel Master CM 3206 Coaxial A/B Switch 75 Ohm High Performance Isolation 80 dB Commercial Grade AB Switch A/V Video Selector Heavy Duty Satellite Dish Off-Air HD TV Antenna Digital Signal Connection, Part # CM3206: Oak Entertainment Centers and Ho
C chadg2 SatelliteGuys Pro Original poster Apr 2, 2006 623 42 Maiden Rock, WI Sep 25, 2011 #3 Thanks, I'll give it a try.
