Until a new Star Choice receiver is actually activated, you will not get Anik F2
channels (all French, foreign language, High Definition, and some sports pkgs) mapped. Once a receiver is mapped, channel 265 (French PPV Info channel) can be used as a permanent alignment channel, which will work regardless of subscription status.
We have been working on a new solution for those caught in the dilemma of not having a 2nd dish ready for F2 when they want to have a Star Choice receiver activated. It involves a Traxis DBS-3500 receiver that we custom pre-program for all Ku-band satellites and channels. An inexpensive in-line satellite tuning meter is added to the mix, creating the ability to perfectly align everything without the expense of a an expensive signal meter, spectrum analyzer, or activated Star Choice receiver. The in-line tuning meter tells you when you are on a satellite. Pointing angles for available satellites are provided, and by alternately listening to the beep and signal level on the in-line meter as well as positively IDing each satellite with the superb metering system found in the Traxis DBS-3500. This technique has allowed quick installation of not only Star Choice systems, but also Ku-band antennas for things such as receive-only Internet service.
The Star Choice 75-E antenna has its place, but it has become very expensive to ship due to dimensional box size tariffs, and there are issues about the non-availability of the Quad LNBF as a spare part. Star Choice customers that take their systems to their vacation homes outside of Canada will find out that there is no quick solution in the event of an LNBF failure. The only remedy is to do a warranty exchange with a Star Choice dealer, which can involve several weeks of waiting and being out of service. About a year ago we started offering a slightly larger (85 cm elliptical, or 30 x 36 inch antenna) antenna from Patriot, which provides needed extra signal for Sun Belt locations and further south. Anik F1R is considerably weaker than Anik F2 once you get into the southern U.S., and there is also the new issue of the loss of at least 2 dB of effective signal from previous levels when trying to receive HD signals from Anik F2 in the new 8PSK format. Those wanting a truly reliable system should use separate antennas for Anik F1R and Anik F2, and the Patriot 85-E makes a cost-effective solution that does not have the excessive shipping charges common with 90 cm and larger round offset dishes.
