Long and Lat Confusion + Coolsat setup
jayelem
1,305
Chicago suburbs.
I need a clarification about satfinder, one of my earlier posting on true south was answered with satfinder data.
North Riverside, IL 60546
Latitude 41° 50.244'N Longitude 87° 49.284'W
Sadoun site has a link to gazeteer and they provided my lat and long as.
Zip Code: 60546 PO Name: North Riverside (IL)
So why is there a difference ?
Also from satfinder, the abreviation AZ M = Azimuth w/ Magnetic Deviation correct ?
I am using USALS on my Coolsat 5000 and IA-8 is not included in their sat list
so I picked a blank renamed it and proceeded entering info, I didn't get very far, so I decided to go for AMC 3, when setting up Antenna Position I assume I fill the blanks for Long and Lat with data provided but found that spaces provided had an extra space so I started with 041.5 and 087.4, Does this look right ?
Weather Permitting I've decided to start from scratch since my help decided to do things his way, and the outcome was no signal, so I'm a little frustrated, I have toggled the frequencies to active Freq using LYNGSAT, and it looks right since Frequencies show correct polarity and SR.
I'm looking forward to FTA, and all who have answered have been helpful.
I have thought about looking for sats with stationary dish setup, but would like to give the motor setup one more try, before taking this route.
At the moment I feel pretty blind as to how close I am to success, I hate to Imagine not being calibrated on pole,motor, and Dish, what a nightmare.
So close!
There will always be discrepancies between the pointing software, but it does not look enough to be a problem.
I would try again for IA-8 and if you do not get it this time remove the motor and find and store a live TP.
Maybe thats the problem, what TP did you use?
Try this one.......
Freq : 11780
Pol. H
SR : 29000
Good Luck!
Latitude 41° 50.244'N Longitude 87° 49.284'W is degrees/minutes which is base 60.
Location: 41.837367 N, 87.821356 W is in decimal format which is base 10.
(50/60) + (0.244/60) = 0.8374
(49/60) + (0.284/60) = 0.8214
If we were talking about time 7:45am (base 60) = 7.75am decimal (base 10)
NEWBIE Twinhan 102g Help.
Adding Motor Positions with Channel Master
