Locals only?
blts
172
WNY
Does anyone know if you can get locals only thru Direct and what it would cost?
but you also have to buy the equipment
Since D* does leases for everything you need at least Choice or possibly the basic that they use for International packages which is $12 + the INt'l channel
Exactly $16.79/month with tax here in Maine.
Then you must have VERY high taxes out there, considering that at the most, it should only require the access charge@$6 + $6 for locals. Or, you must have something else that is making it higher than that. (other prog, DVR or added receiver fees, etc.)
I'm only paying $10, since I'm on the locals only welcome pak, which I believe can STILL be had. BUT as Ice said, you have to have your own equipment. (not leased)
Using THELIST!
FSN Ohio no HD AGAIN!
