I have limited basic with Comcast. All my locals can be streamed through my Xfinity TV app from my laptop through an HDMI cable to my tv. Looks really good considering!! I have a few channels I can't receive via antenna so I stream them. Could use the cable box they provided but it's not in HD where for some reason I have them in HD on the app. Not paying HD fee either. WeirdWhich service do you use to stream your locals?
If you plug a coax connection directly into the tv now you get a test pattern. Really sucks you can't run just coax anymore. Years ago my grandmother was bedridden and I split the main line and ran a line to her room. That was 2003. She was so happy!! My grandfather always watched baseball and news and she wanted her soaps. It made me feel like a million dollars to help her out!!The down side is that you can't stream the locals outside of your "local" network at home. We have Comcast at work, and I can "See" all the channels I subscribe to if I log in remotely through Xfinity, but only certain ones are eligible for streaming. That would be your usual ones of ESPN, TBS, etc.
They have to provide you with that little "hockey puck" cable box in SD because they scramble all their channels now, even the locals. No more clear-QAM with Comcast. In other words, you couldn't just run a coax directly to your TV and view the clear-QAM channels with Comcast anymore. Some cable companies still do (ie Suddenlink)
Back in the day, when I worked for them, we had traps for channels like HBO, Cinemax, and Showtime. I used to hook my friends up!! And my grandparents. I caught my grandfather watching a HBO boxing match!! He also liked Cinemax. When there was an audit, I'd have to retrap the line temporarily until the audit was over and then I'd take the traps back off. In North Georgia you still see traps on the line but they are useless now that it's a rebuild digital systemYeah, it's nice when it works. Had Suddenlink for awhile back in 2015 and they still do clear-QAM (or did). Only needed a cable box if you wanted HD.
I'm a cord cutter and not only can stream all my locals, but have a backup antenna in case of an internet outage or cable and satellite having disputes with certain companies!!
Subscribing to cable television at any level is certainly not cord cutting. Without that subscription, you wouldn't be able to stream your OTA programming as you've claimed. Adding the note that Comcast brings you channels that you can't get OTA pretty much invalidates your claims altogether.I have limited basic with Comcast.
Also, if you are using a cable modem, that's not exactly cutting the cord either. Just sayin'.Subscribing to cable television at any level is certainly not cord cutting. Without that subscription, you wouldn't be able to stream your OTA programming as you've claimed. Adding the note that Comcast brings you channels that you can't get OTA pretty much invalidates your claims altogether.
Cord cutting is primarily about how you get your television programming. That cable is most consumers best option for broadband means that coax isn't all bad.Also, if you are using a cable modem, that's not exactly cutting the cord either. Just sayin'.
Unfortunately, I can't put up an outdoor antenna. It's in the lease. The broadcast stations I want that can't receive are WDSI 61.1,.2 and WFLI .1, .2, .3. Unfortunately, when the signals went digital, you can't get them here in Lafayette Georgia. So cable is the ONLY option for me. And it's limited basic. It's not like I pay sports fees and equipment fees. As far as internet goes, Comcast is the ONLY option in this area. This area is depressed and rural. We are 35-40 miles from the broadcast signals. So I see myself as a cord cutter the best way I can do it with limited basic, Sling, and Netflix. You take what you can get. Nuff saidSubscribing to cable television at any level is certainly not cord cutting. Without that subscription, you wouldn't be able to stream your OTA programming as you've claimed. Adding the note that Comcast brings you channels that you can't get OTA pretty much invalidates your claims altogether.
tvfool.com shows you what is projected for a given address, not just your state.Well if you are looking for an outdoor TV antennas FCC seggest to use à uhf :vhf TV antenna use the tvfool report to helpe you to pick what antennas is best for your state
While Andy may have been a pirate and a rebel back in the day, it is important to "choose your battles" when getting righteous with landlords and property managers.
