I have an DiSEqC 1. 2 motorized dish, I also have a INVACOM LNBF that does both linear and circular. What switch do I use between the LNBF and motor? Also do I need a DiSEqC switch between the incoming cable and my Coolsat 5000 receiver? Thanks
to use both circular & linear, you need a DiseQc switch
you only need 2 of the ports (one from C and one from L). You put the switch between the LNB and the motor. No switch is needed between the motor and the receiver.
