LNBF bracket - special model needed
radiotvsat
4
Virginia
Anyone know of a dealer source for the LNBF bracket for an ITB-USA 4' Ku offset.
It does not appear to be a standard design. The side support arms actually feed into the bracket. (A more traditional design has the side support arms attaching to the center strut.
Please post a photo of the clamp if possible. ITB sold OEM from several manufacturers. I believe that we may have one that is compatible.
Brian,
Do you have any feed assembly/junction blocks that would hold a C-band LNB for offset CM dishes? Looking to play around with a "mini-bud".....
Thanks!
Chuck
Brian,
Thanks!
Chuck
Take a look at our C-Band clamp at http://satelliteav.com/p/shop/?ws_pid=662&ws_cat=433 Would that work?
You will need to fabricate or adapt. I have only seen 23, 30, 40 (and possibly 50mm ??) LNBF clamps for CMs. Our mount should be a good base to modify for the CM mount.
Help with Coolsat 5k and motorized setup
Is PBS really on 125
