lnb setup for dish 500?
deOldePrinter
6
I tried to setup this today and cannot get 110. 119 comes in at 100 to 105 for signal strength. I have the left side lnb hooked up during signal search. This is with me facing the dish with the lnbs between me and the dish to explain what I consider the left side. When I hook up the right lnb to the sw21, I presumed:confused: 110 reception should drop into place. No signal at all. Just 119. Any ideas as to what I am doing wrong?:confused:
what type of lnb is it. is it a single lnb or is it two seperate?
what you are more than likely doing is hitting 119 with the 110 lnb and you will need to move to the left and up with your dish.
Should be moved to the Dishnetwork forum
Sorry about the wrong forum. New member and first post.
It is 2 lnbs in a yoke.
I will post in the forum you suggest.
Thanks for your reply
:eek:
Another good reason not to work satellite install
