LNB question
aristotle73
40
What's the difference between a C-Band LNBF and an LNB that uses an external Feedhorn? Are the offsets the same or different? Do they require a polar motor?
LNB (low noise block, LNBF (low noise block with feedhorn) LNBF does not use a servo motor, I do not like lnbf's becase the built in lnb is garbage and the fact that for a feed hunter some feeds with funky polarity issues will not come in unless you go outside and adjust the feed, I would go with a feedhord and lnb's.
Slaving a DVB Receiver to a DSR922 ...
How-to: Update your Satfinder satellite list
