Hello, I have a old muzak dish 42widex54tall, I have it pointed at 97, works great. I bought a multi lnb bracket the type that is a round tube you bolt on to your lnb arm and it extends right and left of the center, It will hold 3 lnbs. I bought 2 more linear lnbs and am trying to get AMC 9 at 83 degrees. My question is can someone give me some pointers on how far left of the center (97) lnb (looking at it from the front) I should mount the lnb I am trying to get 83 on. And should I point the lnb at center of the dish like the one for 97 is or would it be to one side or the other. I hope I explained this so it can be understood. I have a channel list for RTN with the beep on signal set but I am getting 0 quality. I have the satellite set up as 11750 LO. standard and in my case I run a zinwell 6x8 I use the 22khz. One thing I do not understand about the zinwell markings above the 2 22khz connecters there is also a 13 and 18 v marking. I have to other lines on the
connections marked 13 and 18 volt. Do I have to also choose a 13 or 18 v setting along with 22hz on or off? thanks for any help.
