OTHER linux scanning utilities for DVB cards
ZetaMale
Free speech is more important than your feelings
15,360
10,655
USA
From my research there isn't any true blind scanning utility unless you create an intitial tuning data file. Why is that so? Why isn't there a utility that simply scans thru a satellite where all you do is set a start transponder freq and end freq with user defined freq steps and a minimum symbol rate to search for rather than create and initial tuning file? w_scan is suppose to create such an initial file but it has predefined freq steps and symbol rates to look for instead of giving you a way to set the freq steps and to set a minimum symbol rate. Some info I found gives instructions that say to create a shell script but it makes no sense because it says to pass a freq to szap-s2 but I don't see anything that allows you to pass a freq to szap-s2. Besides, the shell script sounds like a lot of work. Aren't these utilities suppose to make scanning easy? Has anyone found a true blind scan utility for linux?
Reactions: hank123
Fortec Channel Data File for Fortec Star Lifetime Ultra
OTHER Please Help with Low Quality Signal
