Linux EHD Backup on E2 receivers
Corrado
2,431
316
Hudson Valley Region, NY
I find the aging EHD I use on my Edision Mio 4K is nearing the end of it's life cycle. Curious what method other users utilize for duplicating or backing up recordings.
I know the receiver can move recordings between drives one at a time easy enough. What about running a command line in a Linux distro? Seems more efficient. Would the Edision have any issues with permissions if not done in a certain manner on the replacement hdd?
I have gone into our Edision Mio 4K+ using FileZilla running under Ubuntu Linux and pulled recordings off easily. Just select the ones you want and download them to your computer. 🙂
Needs to be tested, but if you config. mounts setup. And get the settings right to use a network share as hdd. Pull your EHD. Recording and backups should go over LAN to the mapped location. Or just replace the drive in the failing unit.
Users Who Are Viewing This Thread (Total: 2, Members: 1, Guests: 1)
