madpoet said:
On the 30" dish... what do you have to replace to get it working? Just the dish itself, or the whole arm unit?
This is the 30 minute procedure that I did myself:
1. Disconnect power to Voom receiver.
2. Remove LNB from 18" dish (easy to do with phillips screwdriver and wrench)
3. Disconnect coax from LNB (easy with small wrench)
4. I stood under/behind dish/arm and made note of where the arm was pointing to on the horizon (this makes it easier to find satellite later).
5. Unscrewed the two bolts that holds the dish to the mount. Lifted dish off mount.
6. Assembled new dish with included arm and rear assembly indoors where it was warm.
7. Brought new dish and installed it on original mount/pole.
8. Threaded coax up through arm and connected to original LNB (used left connector)
9. Bolted LNB to arm (the included RCA style arm is fully compatible with Voom)
10. Pointed arm of dish to same spot on horizon found in step 4.
11. Turned on Voom receiver, connected and brought small portable TV close to dish to help align.
12. Selected "align dish" option from menu to bring up signal meter and sound.
13. Found satellite within a minute and fine tuned within 5 minutes.
Some things to be aware of:
1. If your dish is mounted on your roof, be aware of the fact that this dish is much larger and therefore will catch a lot more wind. Your current mount might not be fastened securily enough for a 30" dish and tear off in strong wind.
2. The 30" dish is a lot heavier than the 18" dish.
3. The arm included with the 30" dish is a few inches longer than the one on the 18" dish. Make sure the coax cable has enough slack to reach the end.
4. The price of the 30" dish is about $30-$40 and shipping is $30-$40. The satisfaction that you did a better job than the "pro", priceless.
5. Even the larger dish does not guarantee that you will never loose the picture. It also does not solve the receiver problems we all read about.
