Since Ill be moving in Jan, I was wondering if there was a larger option than a 1000.2 for 110/119/129 that I would allow me to go back to a 1 dish setup.
Thanks.
Thanks.
Dish is designed for D* it is 1 degree off on spacing for 129 it also is designed for rectangular LNB bases so DP can't be easily used. The 1 degrre error on 129 probably wouldn't be a problem if that was a new powerful satellite,but it isn't. I'd say stay with DISH 1000.2.Andrew SuperGain Dish Assembly allow you to receive up to 3 satellite locations! Configure to your own needs, 119, 110 and 129 (many others) for DISH Network or 119, 110 and 101 for DirecTv. Complete Dish assembly with 3 legacy dual lnbfs, mast, bolt kit and instruction manual to assist with azemuth, elevation and skew. 24" x 36" dish size.
Found this one, its a good bit larger. Any input on the brand?
