This is driving me nuts....
10 ft unimesh dish. Was C band only. Put the corotor II on it for dual band. With a little tuning the cband was fine. Only really concerned with X4 for ku band. The first day got x4 no problem. Next day nothing. That afternoon it came back in. Was getting qualities of 70 ish and higher. Now nothing. I have done everything I can think of.
I figured the focal depth of like 46 by the measurements of the dish but signal is no that great and get nothing with ku band. I see others saying their 10 ft unimesh is around 48 on focal depth. I set it there and c band is jam up. 94 or better all the way around - digital channels quality is 85 and higher on all channels. KU band nothing - signal 10 quality 0............. Yes the receiver is set for dual band lnds - new cable run. Dish has a few dimples in it from hickory nuts but not that bad.
I have the scaler as far out as the arms will let it go - which puts it to the 48 inch mark -
I have tried double checking N/S alignment - reset elevation and declination angle, but could be a off a degree - going to get more critical with it tomorrow to see if it makes a difference. Going to swap coax on lnbs tomorrow to make sure the new cable is good.
Being my cband is tweaked to its max - I am in the arc - no matter what sat I am on - up down left right (pushing) makes signal worse. So I believe I am tweaked in where I need to be. Should I not at least be able to get some signal on one these birds - not one ku band bird - I did have the first day - could the lnb have fried???
How critical is the polar axis alignment with the horn?? it close but not perfect.
hellllllllllllllllllllllllllpppppppppppppp...............
I am beating myself to death here....
feel free to email me anyone with 10 ft unimesh dish - want to verify F and F/D ratio. I may have to go out further ?????????
Any help would be appreciated.....
