I’ve used mine while ice fishing in North Dakota, in -20 and worse temps. Make sure you store it in a dry environment when not using, and a stand is necessary to keep it off the ground. These things are not air tight, and water vapor will fog up the dome, and melted snow and evening/morning dew/frost will makes its way into the gears and motor, and then freeze.
