I scanned in 5 channels, v-me, create, pbs and some others on tp 12180 v 30000 sr, with the Coolsat 5k, and there is no sound. Are these channels ac-3? They are listed as sd in the clear. Can someone enlighten me?
That's what I did.SATisfied said:I need to get a Dolby audio receiver.
Are you saying this file will fix the AC3 issue without connecting it to an amp?Yes, you're right. They're AC3. You won't heard them with your CS5000 unless you use a fix (bin or firmware) that was release some time ago which fix the AC3 issue on the CS5000. Remember you need a computer with COM port and a straight RS232 cable to load the file to your box. There are also some channels in this sat that are DVB-S2. Those there will be no way you can see them with your Cs5000. You will need a MPEG-4/HD , DVB-S2 FTA box. Here is a direct link to the files. I also included the Cs5000 loader so you can load your new file to your box, Good Luck!!
COOLSAT5000_006p_20091223-3rd party bug fixed.zip - 4shared.com - online file sharing and storage - download
CoolSat Pro Loader v.2.4.zip - 4shared.com - online file sharing and storage - download
So now I'm really confused.
Does this file allow the coolsat to get AC3 audio. Yes or No
