I just got it install today 5/27 Both of my H23's see each others DVRs both it skips when I play from one another. Can you guys give me any points or should I call the them to come back
The living room DVR is connected with both the directv deca connection and connected to my router so I can use VOD the second DVR is just connected with deca connection.
Are you saying that the LR DVR is using both a DECA connection and an ethernet connection?
If that is true, then that is a problem. To connect your router to the DECA cloud you need a separate DECA connecting to the router.
also sounds like maybe the installer didn't use a large enough splitter for 1 DVR and 2 non DVR you would need at least a 4 way or an 8 way if you have a Broadband Deca
