Okay so i'm going to order my system tomorrow..and well i went out to my "planned installation spot" with a johnson angle finder, and a compass...just to see something..i picked two satellites, SBS 6 and IA5, so i guess im asking if what i did will give me an idea to whether or not my dish will clear the roof. I found the correct azimuth on my compass, then took my johnson angle finder, it appears that the pitch of my roof is 20 degrees, and the elevation angle for IA 5 is 53.3 degrees and SBS 6 is 45.5 degrees. So assuming that my dish was mounted at the same height above ground as the eve of my home...then I would set the motor elevation at 31.5 degrees and then set the dish at 41.5(for the type motor I will be ordering, then hypothetically i should clear the roof by some 21.5 degrees, is this enough in everyones opinion to be a good place to mount? I realize it's probably hard to answer that question without seeing what im talking about but it looks like i'll have 21.5 between the roof line and IA5. I hope this all makes sense..im just trying to educate myself as much as possible. I think i really should be able to do it just fine..just can't wait for the thing..hopefully i can get it by mid week next week.
