Got up this morning and no 110.
I ran a check switch and 110 couldn't be found, so I cancelled out so it wouldn't drop it from my settings.
I've no idea which transponders I should check specifically, so this was kind of random. Checking signal on 110, transponder 15 gives me a brief signal at a strength of 17 then drops off. Transponder 19 gives a signal of 6.
119 & 61.5 are fine.
I have a Dish 500 with 2 LNBF's pointed at 119/110. I have a separate Dish 500 with a single LNBF pointed at 61.5. (Years ago, an installer added the 61.5 so I don't know if he upgraded/changed the 119/110 LNBF's to a twin or not.)
Anyways, these go to a DP34 and from it I have 2 coax's going to my 622 and 2 going to my 722.
This is going to 1 TV and the behavior is the same on either box.
Do you think my problem is aiming or switch?
This is really out of my league, so I may not be telling you what you need to know. Forgive my ignorance. I'm hoping some of you will tell me you're having the same problem, so it's not just me. But given I've seen nothing on the boards as of yet, I suspect it's me.
