Is there an KA FSS birds out there in US?
What do you mean?The combination of Ka and FSS seems an unlikely combination for TV.
I meant what I posted.What do you mean?
Up to the point that DIRECTV had a couple of broadband satellites that they needed to repurpose (Spaceway 1 and Spaceway 2), Ka was a band primarily used for data. The way they treat it, the bandwidth yield is relatively poor (6-7MHz per HD channel with AVC compression?). Adding FSS to the equation probably doesn't make it better if one of the key goals is to use OTARD permitted dishes.
Unless Ku band is completely used up, why bother?
File delivery and TV delivery are two different beasties. TV delivery to STBs must be linear while data delivery has no such requirement. Data delivery is typically not as time-dependent as TV.Is this televison delivery by Ka?
