Hello,
I have an 811 hooked up to an HDTV that is capable of doing 720p or 1080i. I would like to be able to set the receiver to output in the native format for the channel, so when I am watching ABC for instance, it is output at 720p, but when I watch NBC which originates in 1080i, it outputs 1080i. The receiver seems to only have the option of saying you have a 1080i display or a 720p display, though, and won't let you select that your display can do both. Is there any way to get the receiver to output whatever the resolution is to the TV? I know the Voom receiver could do this when I had them, seems that the Dish receivers should be able to do so as well. Also, does anyone know if ESPN through Dish is sent at 720p, or are they changing it to 1080i before sending it out?
Thanks.
Sean Dudley
Thanks.
Sean Dudley
