I realize you can edit names and stuff in edit tp menu, and can move channels in edit channel menu of the Pansat 3500 sd, but is there a way to move the locations of satellites in the list up and down so that you can line the satellites out from east to west or vice versa, without having to manually change sattellite names and what not? When you sort channels by satellite it defaults to sort by the order in the satellite list. There doesn't seem to be a way to change that list so that sorting by satellite will make the line up from east to west go well without manually renaming every satellite on the list and redoing a blind scan on each. For now, I've manually moved a lot of channels up and down the list in edit channel and am just using that for now, but it'd be nice if I could get it to just sort by satellite and all the channels on each satellite would be together, ordered from east to west. I don't dare touch the sort by options as everything is ok for now, but when I scan in more channels, it gets annoying having to drag them up and down the list of around 400 or so channels.
I have mnost of em ordered from East to West at the moment so that G10r shows up as like the 3rd or so channel and up, with White Springs as channel 2 and the "election" channel as channel 1.
Too bad they don't have a sort by Usals degrees with an option for east to west or west to east.
