I have a coolsat 6000 and reading another thread people mentioned the possibility of using it's loopout to connect to a pc tuner to get HD signals, so I was wondering if there's a tuner that can get both HD AND 4:2:2, preferably below 100 bucks
If I were you, John, I'd just google the question and see what comes up, or just enter the key words USB TV tuner HD 4:2:2.
I'd also go to Newegg.com and Tigerdirect.com and see what they have.
4:2:2 has nothing to do with the tuner in an STB or PC.
4:2:2 is how the colours are encoded. To view 4:2:2 streams it's just a matter of having the right codec on your machine so that it will decode 4:2:2.
Elecard is one, ffmpeg is another. Elecard costs $$$ and ffmpeg is free. I'm sure there are others.
I have an old USB Hauppague tuner I bought in 2003
so by connecting the loopout of the coolsat to this thing would I be able to decode those 4:2:2 feeds? you mentioned ffmpeg, what other software would I need to watch the feed, VLC? WMP?
NO! don't do that, that card is only for OTA TV (so is that site), you might damage it (or the Coolsat) if you connect it to the loop out. You need a satellite PC tuner card (DVB-S or DVB-S2 PC Tuner card)
Loop out passes the L-Band frequency from the LNB (950 MHz to 2150 MHz) exactly the same way it receives it unmodified, so you need a satellite tuner to work with it.
At Sadoun scroll down and look at Sadoun FTA Receivers #'s 4 - 7
Galaxy-Marketing sells the Matchbox Pro USB DVB-S Box
If you can find at other places and don't need DVB-S2 capabilities then the Twinhan's are good cards. You should be able to find the Twinhans for less that $100.
I like the Twinhan 102G for DVB-S and for its ability to work with TSReader, and the DVBWorld USB tuner for DVB-S2.
....so if I buy let's say a matchbox pro i can theoretically get HD signals plus 4:2:2 with the appropriate codecs right?
Your concerns of HD and 4:2:2 now require a powerfull enough PC and/or a powerfull video card to decode the streams.
First look at what types of signals you want to watch. Do they require DVB-S2 or just DVB-S. In general a DVB-S2 card/box will also receive DVB-S as well. Also for some of the Dish signals when they are in the clear, you will require yet again another type of tuner. turbo 8PSK???? (or something like that, others here can tell you which tuners for those signals) The tuner gets the stream into the PC and then the codecs decode the streams. Some streams only require minimal computer power, while others require great decoding ability. Some video cards will help out in the decoding of these streams.
