I had a 2H/3J system installed last Friday. The local installer I used didn't have a HIC on the truck so he ordered one and brought it by today to install. According to the wiring diagram, on a 2 hopper system it shows the HIC installed as a pass through to a Joey on a client line. Well the installer and I were both pressed for time (I needed to get back to work) and I don't have an Ethernet line anywhere near a Joey. So he wired it according to the 1 hopper diagram with a solo node. Which shows using a tap with one side going to a hopper and the other to the HIC. At the time everything seemed to be working correctly. We went to each receiver and clicked on broadband and they all showed the home network connection as "connected" and an IP address for each one.
Now that I'm home from work I've got some time to play around. I can go into On Demand and begin searching shows. But after a minute or so I get the "attention 145" error. Which states "server connection failure. The receiver is unable to connect to the network server. Please try again later". I have to think there's something in the HIC that's causing this. Over the weekend I had the same hopper connected directly with Ethernet and was able to download and watch shows On Demand.
One other thing. The installer didn't have a Dish tap on the truck (he thought he did). But he did have a high frequency Directv splitter. Could that be the problem? For some reason it works, but it seems to be intermittent.
