Hi all, I hope someone can help point me in the right direction.
I have a 322 (and a 722 that's working fine on all tuners). There are two dishes mounted--a separate one for 129.
By the way, I've no idea what the switch setup is. If there's a switch, it must be up on the roof, because I can't find anything down where the cables go into/out of the house.
On the 322, I can only use one tuner at a time. Whichever tuner is working tunes in everything perfectly. The other tuner will remain on the "Acquiring satellite signal" (#015) screen and eventually show an error screen (#002).
If, while on the tuner that's not working, I press Menu 6,1,3 and select yes to the warning about the other tuner being in use, the system info process goes. It ends by showing all three satellites with a big red and white X for the signal.
However, when I select "Done" on that process, that tuner is working and the OTHER one now is unable to acquire a signal.
If I repeat this process with the other tuner, the exact same thing happens.
It's been this way for a few weeks, but I've been on vacation. I've tried restarting using the front panel power button and by pulling the plug. This behavior appears to be consistent.
So what is the culprit: a switch or the tuner or something else?
Thanks for the help!
