Everyone put on your thinking caps.
Is it possible to control 2 different diseqc positioning motors with the same receiver?
I am currently using a Pansat 3500 to control a Vbox II which in reality is the same as controlling a diseqc motor. I currently have a diseqc swith with port 1 for KU and port 2 for C-Band.
If I were to put up a Primestar dish and wanted to motorize it with an SG2100 or other diseqc/usals motor for KU only, and say I have a C-band sat on position 20, and I want to have a KU Sat also on position 20, is there a way to have the Pansat/diseqc switch be made to send out the signal to move the SG2100 when on port 1, and not signal the Vbox?
There are 49 positions available in the Pansat for storing sat positions from the factory. 1-27 for usals I think, and 28-49 for everything else.
Another possibility is to set up USALS only for the KU, and use diseqc for the Vbox. Would that work?
What other options are there for making this kind of setup work other than having a second receiver for KU only to control the Primestar?
Just wanting to explore options, and see what the expense will be to have two different motorized dishes running at the same time.
Thanks, Fred
Thanks, Fred
