jerryt said:The larger the dish the more space between lnb's.
For example, Standard 18" dish the DBS lnb's are side by side with 9 degrees between the satellites.
But on a Toroidal T90 dish (43" X 39") the recommended LNB spacing is 3 degrees. and on my Primestar multi-LNB dish (36" x 24"), I can get 5 degree spacing.
The bigger the dish the more space between LNB's. If you had a six foot dish, you could get a couple of degrees spacing.
But motorized system is the way to go, because you can get ALL the satellites in your arc.
Thanks! The T90 is sitting on the shed roof, face down. If this thing comes any closer, the toroidal will have to come inside again. It's a big bugger....Iceberg said:Hang tight Tron
jerryt said:You could try and get both with the 43" X 39" primestar dish. Aim for the weakest satellite with the lnb in the center, then hunt for the second satellite right next to the first lnb.
Remember two things;
1) The second lnb will need to be on the opposite side from the center lnb. So if the second satellite is west of the center satellite. You mount your second lnb on the East side of the center lnb.
2) The dish will need to be skewed at the correct angle so that the second lnb can be side by side with the first. Note how Directv dishs are skewed for 101/110/119. Again the skew is opposite of the actual satellite positions. Like looking at a mirror image.
