'Is it possible to put 110, 119, 121 on one 33" dish? TKS
sheyuid
Can someone tell me is it possible to put 110, 119, 121 on one 33" dish? How to install ? TKS!!!
Yes. You can install 5 LNBFs at least for the dish; one problem is how you can manage to hold them ? I'm using a cluster from SD105 plus a couple LNBFs on zipties and wood inserts.
What receiver do you have? Some receivers can't see 121 in the setup
Otherwise a Superdish would work better :)
Yeah - as Iceberg says, what you want is a 121 SuperDish.
Which just happens to be around 33" in size strangely enough.
(I'm using coolsat 4000 pro clone, it can see 121). Someone tell me 121 and 119 is too close, so I can not attach 2 lnb. Is it true?
Cheapest AC3 Decoder I've found.
frequency 1 MHz off
