I added a radioshack in-line amplifier to my OTA antenna. It is an indoor antenna (silver sensor) connected with a 30 ft piece of rg 6 coaxial . It really does not seem to boost my signal much if at all. Is the amplifier useless with this antenna? Does the dc block weaken the signal?
the installation instructions for the amplifier say to keep the dc block on when using a 300ohm to 75 ohm transformer but my antenna does not need one because it has a straight 75 ohm connector that I can screw the coaxial into directly.
Would taking the dc block off create a short circuit? Or would taking it off help increase my signal? Or neither. As you can tell I am not very knowledgeable. Any help would be appreciated
