Is a Duo Node required when using a DPP44 switch?
CK SatGuy
Formerly ckhalil18
4,023
112
The Motor City
Just curious about something since I use a 1000+ with a DPP44. It seems that the only wiring diagrams I see when using a DPP44 also use a Duo Node. I understand those diagrams show 2 hoppers instead of just one, but it makes me wonder: Is a Duo Node required when using the 44 even if you only have one hopper? Or would a solo node still work just fine?
solo node is fine. Put the power inserter on #1 and the solo node goes to 2 and 3.
if you ever got a duo node, then it would use the fourth port as well.
Help with dishonline and sling adapter
Hopper Commercial Misleading
