Hi All,
Background:
I am planning the wiring right now and would like to select the solution with the least amount of switches/patch cords. Plans are to use a motorized 1.2 meter KU only dish with Invacom Quad LNB. I would like to use a Zinwell 4x4 Multiswitch with 22KHz, which would select linear or circular polarity. Set no 22KHz tone for linear and 22KHz tone for circular. I would like to drive up to 4 receivers with the primary receiver (a Pansat 9200 HD) having motor control. The secondary receivers would be a Quali and future Starchoice DSR505 HD.
Problem
Since the DSR505 uses 22KHz to switch between the 107 and 111 sats, I would need to be able to block (filter out) the 22KHz signal at the receiver so the polarity will stay linear (and not switch to circular when the 22KHz tone is enabled).
A search of the WWW mentions that a Taiwan company manufacture them but there's nobody selling these that I can find.
thanks,
Joe
Background:
Problem
thanks,
Joe
