Invacom SNH-031 LNBF
Questions:
These LNBF's are .03 correct?
What is a Primestar LNBF which I currently have?
Is there considerable improvement?
I have trees that block G11, IA6 & G3 in most of the backyard that effect those 3 dishes. Is it worth it to buy one, two or three?
These fit right onto the dish, correct?
Thanks for answering if you know.
Yes they are 0.3 db. The P* LNB's are 0.6db or higher!
They have a 40mm neck so are the same size as a standard LNBF and should fit all FTA dish, they also have a 120mm flange version that can simply bolt on to a P* or DirecPC feedhorn.
A low noise LNBF may help slightly with a less than perfect line of sight, but I would not bank on that, it will only get worse as the trees grow.
watchin birds outside of the US??
HELP!!! set up, program andchannel
