If the L.O. is off then doing a blind scan will show all the transponder frequencies off by 5. Not a real problem. But if you input the transponder frequency manually you may not get it because of the shift in L.O. Because it's a Universal LNB your Hi-Lo band switch is 5 off also so it may cause an issue getting signal at the edge of the range of each band.
