Installing Dish - What am I doing wrong?
GJvdB
4
I just bought an new 33" dish, LNBF and receiver so I can watch BVN tv from the T-5 satallite. But I can't get it to work. As far as I know I installed everything as it is supposed to be done. I'm in Jacksonville Florida. Installed the dish at: Azimuth 207, Elevation 51. Correct cable and directly ground wired the dish. With my satfinder I'm getting a strong signal. But my tuner seems not to get the (right) signal. Low Signal Strenght and Low Signal Quality.
What I'm I doing wrong? Is there something in the settings of the tuner I need to change?
Tuner: Digiwave DG7000
LNB: Gigiwave, Standard KU LNBF, Digital Ready, DG 668, RF: 10.70 / 12.75GHz, IF: 950 / 2150MHz, LO 9.750/10.600GHz, Gain: 55dB, Noise Figure: 0.5 dB.
The channel I'm most interested in: BVN TV, 11929, V
Information Setup Screen:
- Antenna Setup: 1
- Type: Fixed
- Satellite: T-5
- LNB Type: Univ
- LNB Freq. 1: 9750
- LNB Freq. 2: 10600
- 0/12 Volt: None
- 22KHz: None
- DiSEqC: None
- C/Ku Band Control: None
Channel Seach Screen:
- Antenna: 1
- Satellite: T-5
- Position: Disable
- Transponder: TP5
- Frequency: 11.929
- Symbol Rate: 22.000
- Polarization: Ver
- 22KHz: X
- Strength: 60
- Quality: 40
Can I watch the buffalo sabres this year?
Direct Tv Tivo A paperweight?
