Task: Installing my Dish TV (500) with my existing cable TV.
Existing Equipment:
1.Cable TV (Brighthouse)
2.DVD,VCR
3. Dish Receiver & dish signal
4.FutureSmart structured wiring system which distributes TV/Phone to entire house
5. NetMedia 3 channel modulator, which carries the DVD & VCR.
Goal: To distribute the Dish signal through the FutureSmart system.
Existing problems:
1. I can find only 1 clear cable TV channel for the NetMedia modulator to operate on. I previously used 3 channels, but something has changed with the Brighthouse cable channels and have lost use of 2 other channels. I have spent much time on searching for available TV channels.
2. FutureSmart literature says that the incoming Dish coax cable must not be connected to the "signal-in" module on the FutureSmart equipment because of voltage load on the Dish signal, which could possible "wipe-out" the equipment.
3. The NetMedia Modulator literature shows a diagram with the DishTV signal directly connected to the Dish receiver (SAT. IN) which is then patched out of the receiver to 1 channel of the NetMedia Modulator. The modulator signal is then routed back to the FutureSmart Distribution module and connected to the "Modulated Signals INPUTS". THIS CONFIGURATION DOES WORK, however:
1. The TV picture quality is not acceptable (line inteference from?)
2. I have to use the only available TV channel for the Dish TV which means that I have to manually change cables when I want to use the DVD or VCR.
In discussing this with others there has been a suggestion of using a "Splitter" for the incoming Cable & Satellite cables. I'm afraid to connect the satellite coax in front of the FutureSmart modules because of Existing Problem #2.
Another suggestion was to "blank-out" the cable channel signal to free-up a channel(s) for the modulator to work.
I will greatly appreciate help.
Larry
Existing Equipment:
2.DVD,VCR
Existing problems:
Larry
