How is an installer going to be able to put new wire in if I'm only allowed on wall punch-through? (Which I assume is to bring the cable to the box?)
I already know the installer will need new cable to go to the receiver. I had hoped it wouldn't be necessary, since as I've said, it's pre-wired for cable, and I don't feature having a nasty cable running down my living room wall.
However, for the Receivers' connection to the *second* TV, I was under the understanding that this could use existing housing wire (since power for the Dish isn't an issue for the second TV). Is a nasty cable going to be running up my stairs as well? If so, i need to.
I will check my cabling tonight... hopefully it's all RG-6 already. Like I said, this wouldn't be such an issue if they gave some details install info at dishnetwork!
And my final question is, when I signed up for install, I requested the HBO/Cinemax movie pack. I want to change to HBO/Showtime. Do I need to change this before the installer comes, or can I just do it when I activate? Just want to make sure everything is ready. I've already marked which cables go to which room of the house, in case that's useful for the installer.
